Jolene
Sep 16, 2018Follower
Set up of WN3000RP
Hi
I'm trying to set up this extender to support a Ring floodlight cam, but aksthough the network has been set up and recognised it's saying there is no internet access. Does that mean it's not properly set up? How do I sort this out?
TIA
1 Reply
Try connecting a PC or mobile device to the WN3000RP's wifi network, and then browse to mywifiext.net.
If you can see the extender's IP address in your router's attached device list, then you can also browse to that IP address.
That will give you access to the configuration and status, so you should be able to tell if the extender is connected to the router network or not.
