glemme
Mar 08, 2016Aspirant
Setting country code on EX6150
I am setting up my EX6150 and one thing that annoys me is that I cannot set a country code on the device. It has now defaulted to FR and I am not located in France. This might seem like a small i...
DarrenM
Mar 09, 2016Sr. NETGEAR Moderator
Hello glemme
you should be able to change it on the wireless settings page on the extender. Is the box greyed out? have you tried a different web browser?
DarrenM
- MrCrankyJul 16, 2016Aspirant
The settings page, for firmware revision V1.0.0.16_1.0.58 at least, has no such setting, or check box to be greyed out. It lets you pick 'Europe' or other regions, but does not let you choose UK vs FR, almost as if it's deliberately picked a random country in Europe and is using that. Is there no way to be more specific about country?
- DarrenMJul 19, 2016Sr. NETGEAR Moderator
Hello MrCranky
Is the setting being set to Europe causing some type of issue?
DarrenM
- MrCrankyJul 30, 2016Aspirant
Well as the original poster commented, Apple products complain about the country mismatch. When testing connectivity issues with my main network (which I am having, but which I don't believe are country-code related), it is throwing up complaints about country code mismatches in the report, because the EX6150 happens to be the first network it finds, and from there on it thinks that all other networks should be FR, and raises a bunch of errors because every other network around here is UK. To avoid these complaints and stop them obscuring the test results, I have to turn off the EX6150 while testing.
