Merlotmike
Dec 28, 2018Follower
Setting up guest access on extender ex6110
How do I set up the extender to run only on my guest network on a AC1200 EX6110 ?
- Dec 28, 2018
Reset the extender, and join NETGEAR_EXT. After that use the web browser setup method, and connect the extender to your router's guest network.
Instructions are on page 11 (Connect with the NETGEAR Installation Assistant) of the user manual here: http://www.downloads.netgear.com/files/GDC/EX6110/EX6110_UM_EN.pdf
Dec 28, 2018Guru - Experienced User
