Fredbird82
Apr 16, 2017Aspirant
Setting up multiple AC1900 Nighthawk Wifi Range Extenders
I want to setup a second AC1900 Nighthawk Wifi Range Extender. I have one at the north side of my house and it works great. I want to add a second one to the south side of my house. 1. Will T...
TheEther
Apr 16, 2017Guru
- Yes.
- It might be the same, but you can always rename them.
Fredbird82
thank! How do I rename them?
- TheEtherApr 16, 2017Guru
Log into the extender at mywifiext.net. You need to be connected to the extender. Check the manual if you need help.
