leslyons
Jun 13, 2016Aspirant
Setting Up Two Netgear WiFi Range Extenders on the Same Network
I live on a ranch and the only connection to the internet available to me is through my Verizon MiFi Home device (Novatel Wireless, Model number NOVT1114V). I have three buildings close together, whe...
DarrenM
Jun 15, 2016Sr. NETGEAR Moderator
Hello Leslyons
You would just need to connect a device to the extender then open a web page and go to www.mywifiext.net login with admin/password and you should be able to change the SSID of each network.
DarrenM
- leslyonsJun 21, 2016Aspirant
Thanks! I will try that.
