ksadiq79
Aug 19, 2015Follower
Setting WN3000RP Range Extender with Same SSID as of Router's
Hi, I have a DLink Wireless Router & have setup a Netgear WN3000RP Range Extender with it. Currently I'm using the default settings of different SSID's for both the Router & Range Extender. Now I...
- Aug 19, 2015
Changing SSID . Page 23.
netwrks
Aug 19, 2015Master
- madpeanutSep 21, 2015Aspirant
But does changing it allow the router and extender to determine which the device is closest to and join that? I have a similar question and I'm wanting to make it work like I have at work with business class hardware but for home hardware at my house. When I roam the building at work I'm always connected to the same SSID. At home, I know which extender I'm connected to but hate having to manually switch but want to make sure that the device will connect to it just fine and overlapping signals won't cause the device to get confused. For my place, due to the walls and layout I'm going to need multiple extenders and want to ensure its not an issue with all the devices using the same SSID.
- nhannSep 22, 2015NETGEAR Employee Retired
Hi madpeanut,
Unfortunately, the roaming network you described is a feature more common in the business product line. Your network connection may vary when naming all the networks with the same SSID.
http://kb.netgear.com/app/answers/detail/a_id/24942/~/how-to-set-up-my-wireless-extender-to-use-the-same-ssid-as-my-router- nrichardDec 02, 2015Aspirant
Hello
But is there any point having the same SSID? Will roaming be faster between the 2 Access Points, compared to disconnecting from SSID-1 and connecting to SSID-2, if both are set as "Connect automatically" (in Windows)?
Thanks
