Eejayb
Jun 28, 2021Tutor
setup no WPS
Can I setup if my router does not have WPS? If so how?
Eejayb
Jul 07, 2021Tutor
Well I tried all the suggestions from the community but still my extender will not work.
WPS no connection found
Web Browser - cannot find network.
As community cannot help I will buy a TP link or some other wifi extender that does not include NETGEAR!!
Also tried the feedback link set by netgear for my "Did you get the answer you needed?" feed back but the link fails so evern my feedback cannot be given!!
Jul 07, 2021Guru - Experienced User
so you hardwired a pc/laptop into the extender and attempted setup that route?
- EejaybJul 07, 2021Tutor
Yes as I stated I tyried all the suggestions from the community and they have convinced mr that my route to extending my wifi lies elsewhere. I am researching TP Link and others at this time before I purchase a replacement. I will carefully check the after sales support then make my decision.
So thank to the community for the help offered
