pdmike
Jan 03, 2019Tutor
Setup Question Involving Configuration for an NG Universal Wi-Fi Ranger Extender, Model: WN2000RPT2
My Range Extender has a WPN button and so does my router. If I "introduce" the Range Extender to the router by using the WPN buttons on each device, is that all I need to do to configure the Range E...
pdmike
Jan 03, 2019Tutor
I meant WPS button .....
- StephenBJan 04, 2019Guru - Experienced User
You can use WPS, the details are in the user manual here: http://www.downloads.netgear.com/files/WN2000RPT_UM_05MAR2012.pdf
If it fails, then use the web browser setup method (which isn't difficult, though it might look that way on the video).
- pdmikeJan 04, 2019Tutor
Thanks. I know I can use WPS - that wasn't my question. My question is, is one better than the other? I did download and print up the manual and I did read it (RTFM). The manual seems to say that if your router is equipped to handle a WPS configuration, that is the best way to go and you should only use the computer configuration method if WPS is not available. This implies (at least to me) that either method reaches the same result, that one way is no better than the other. Would you agree?
