Dithyrab
Jan 07, 2019Aspirant
Severe Throttling on bandwidth with Nighthawk extender upgrade
Hi,
Sorry it wouldn't allow my model in the subject bar, I am upgrading my older netgear extender (N600) to a Nighthawk AC1900 EX7000. I use this extender via Ethernet to my PC to boost the signal ...
Dithyrab
Jan 08, 2019Aspirant
Everything i read says the Firmware is up to date on mywifiext.net. It's not a router though, it's an extender. Model number in OP, but Nighthawk AC1900 EX7000
Jan 09, 2019Guru - Experienced User
Yes, but the router could be related to the performance issue, so it's helpful to know what it is.
There are some issues with the newest 1.0.1.76 firmware. So you might want to try downgrading the firmware to 1.0.0.66. https://kb.netgear.com/000059563/EX7000-Firmware-Version-1-0-0-66
- DithyrabJan 09, 2019Aspirant
thanks, i'll check it out and update my post when i know more.
