Gili756
Jul 12, 2018Aspirant
Signal Strength LED stays on RED continuously
Something bizarre is happening with my unit: per instructions I located the unit in the same room with my dual band router (actually, about 2 feet away from it), and began setting it up. Now the stra...
DarrenM
Jul 16, 2018Sr. NETGEAR Moderator
Make sure the unit is on the latest firmware and them you may want to try and factory reset the unit by holding the reset button for 10+ seconds then set the extender up again.
DarrenM
- Gili756Jul 17, 2018Aspirant
Actually, all has been resolved without a factory-reset. It turns out my 2.4GHz band became disabled during the initial setup. Once I reran the smart setup, I was able to reactivate the 2.eGHz band. Now both bads are active, and all LED's on my extender are a steady white. I haven't had any other issues since running the smart setup. I am a very happy person right now.
