arxcakes10
Jul 23, 2017Follower
sip alg
Ive started a new job that requires me to have SIP alg option on my router as some routers have this permanently enabled or disabled, which netgear routers have this option?
TheEther
Jul 23, 2017Guru
Not sure why you posted this in Range Extenders forum.
Anyway, AFAIK, the SIP ALG option is a standard option on Netgear routers. You can always double check the online documentation at http://support.netgear.com.
