kerjak
Aug 14, 2016Aspirant
SSID ADDRESS ON EXTENDER AND ROUTER A GOOD IDEA OR NOT?
Hi, hope someone can offer some advice on this please? Purchased above extender to connect to Nighthawk AC1900 Smart WiFi Router, which it has done. I thought, possibly stupidly, my devices woul...
kerjak
Aug 15, 2016Aspirant
Hi Ether,
Thanks for response.
Could you explain how I actually do this? I have Netgear Genie installed on PC.
Also, I believe I can make extender into an AP as I have ethernet available at top of house,
Would this be better than above solution?
Thanks,
kerjak.
TheEther
Aug 15, 2016Guru
Running an extender as an AP is always the preferred solution. I believe the EX6150 has a switch to enable AP mode, so make sure to slide it into the correct position. Log into the extender at mywifiext.net and proceed to change the SSID to match your router's SSID.
- kerjakAug 15, 2016Aspirant
Hi Ether,
Thanks again.
I have set up extender as AP and connected. I am unable though to get into the settings of extender via genie to change SSID's. I can get into settings of main router via genie by logging in as "At home", username is admin and Password is password. It won't let me login to extender/AP using these details and I'm 100% positive I have not changed these.
I have created a login to mynetgear.com but that doesn't seem to let me alter any router/extender settings on there.
I'm assuming because SSID's are still different I will see router and extender/AP as different networks on genie?
Thanks,
kerjak.
- TheEtherAug 15, 2016Guru
I don't use Genie, but I suspect that it's not capable of managing extenders. You should be able to log into the extender using its IP address. Alternatively, join the extender's Wi-Fi network and point a browser at mywifiext.net.
