Dargy
Aug 13, 2018Aspirant
Suddenly My Wifi Extender Won't Connect To One Device While Others Can
So the other day i was on my ipad and suddenly the connection cuts out. As i try to reconnect to my wifi extender, it just stopped connecting all together. It will let me reglog /select to connect t...
Christian_R
Aug 13, 2018NETGEAR Employee Retired
Hi Dargy,
Have you tried forgetting the network in the iPad settings and connecting to it again?
Christian
- DargyAug 13, 2018Aspirant
Yes, ive tried doing that many times but still the same result. It loads as if its connecting ,but i get the "no internet connection" text.
- StephenBAug 14, 2018Guru - Experienced User
Have you tried connecting the iPad to the main router (just to confirm that this is specific to the extender)?
- DargyAug 14, 2018Aspirant
Yes i tried connecting to the main router and i am able to connect to the router and get connection just fine. Its only when i connect to the extension that suddenly stopped working.
