Dargy
Aug 13, 2018Aspirant
Suddenly My Wifi Extender Won't Connect To One Device While Others Can
So the other day i was on my ipad and suddenly the connection cuts out. As i try to reconnect to my wifi extender, it just stopped connecting all together. It will let me reglog /select to connect t...
Christian_R
Aug 13, 2018NETGEAR Employee Retired
Hi Dargy,
Have you tried forgetting the network in the iPad settings and connecting to it again?
Christian
Dargy
Yes, ive tried doing that many times but still the same result. It loads as if its connecting ,but i get the "no internet connection" text.
- StephenBAug 14, 2018Guru - Experienced User
Have you tried connecting the iPad to the main router (just to confirm that this is specific to the extender)?
- DargyAug 14, 2018Aspirant
Yes i tried connecting to the main router and i am able to connect to the router and get connection just fine. Its only when i connect to the extension that suddenly stopped working.
