wfarid
Jan 10, 2019Initiate
Suggested setup for a Netgear X4s with Ex7000
I have a Netgear Nighthawk X4S 7800 and and Range Extender EX7000. Currently I'm using the EX7000 extender as a wireless bridge so that I can connect my desktop to my network/internet (it doesnt have...
Jan 11, 2019Guru - Experienced User
wfarid wrote:
I was wondering if i would benefit from fastlane?
Fastlane dedicates a radio to the backhaul connection between the extender and the router (not using it for client connections to the extender).
Since you aren't using the extender's wifi client network at all, you are getting the same benefit in a somewhat different way. So there is no reason to configure fastlane on the extender.
Though you might want to confirm that the extender->router connection is using 5 Ghz.
wfarid wrote:
Or if there are any other settings I can enable.
I don't think so. Are you thinking the performance is inadequate? What speed are you getting (say with www.speedtest.net)?
wfarid
Jan 11, 2019Initiate
My speed is actually quite good. I was just wondering if I could improve it in any way. Thanks for the feedback! And yes it is def connected and operarting in 5ghz AC.
