8ballpoolapk11's avatar
Jan 07, 2025
suugest me a wifi router
Looking for recommendations on a reliable Wi-Fi router under $100 that supports strong signal coverage for a 3-bedroom house. Any suggestions?
1 Reply
  • plemans's avatar
    My suggestion? Check amazon for renewed routers.
    the RAX70 can usually be found for that price renewed and so can the RAX50.
    both would get you to a solid single router solution.
    If you're wanting a mesh, you'd need to up the budget a bit for what I'd recommend.
