reddesign1992
May 20, 2017Aspirant
The disc image file is Corrupted
I cannot download the software to get it set up. Getting error code "The disc image file is corrupted" Frusterating that I cannot find chat help or phone help to resolve this.
reddesign1992
May 21, 2017Aspirant
How does it know which signal to boost? We have had 5 adults work with set up instructions and cannot get it!
TheEther
May 21, 2017Guru
To set it up, you need to connect to the extender's Wi-Fi network. By default, it will be called NETGEAR_EXT. After you connect to it, point your browser to mywifiext.net. This is not a real website; it will connect you to your extender. If this is the first time logging in, you should be taken through the setup process, where you will select the signal to boost.
For reference, here is a link to the manual.
