reddesign1992
May 20, 2017Aspirant
The disc image file is Corrupted
I cannot download the software to get it set up. Getting error code "The disc image file is corrupted" Frusterating that I cannot find chat help or phone help to resolve this.
reddesign1992
May 21, 2017Aspirant
Then what username and password do I use?
TheEther
May 22, 2017Guru
You should not need to enter a username or password if you perform the factory reset correctly. It should take you through the setup process where you will create a username and password.
