LGH50's avatar
LGH50
Tutor
Mar 15, 2023
The router and the extender sometimes assign the same IP address to 2 devices
Extended network using Nighthawk RAX43 router and EAX 15 extender.   The combined network performs well for days - weeks, but then connections become unstable. Reason is, the main router and the e...
  • plemans's avatar
    Mar 16, 2023
    Not a whole lot 🙂
    Just set the extender and the 2x devices with issues up as reserved through the primary router.
    One other thing to do. If you have mac's/iphones on your network disabled private mac/ip address and icloud relay.
    They can cause different ip addresses to be assigned. there should be plenty but maybe over a couple days if you have multiples, its causing issues
