LGH50
Mar 15, 2023Tutor
The router and the extender sometimes assign the same IP address to 2 devices
Extended network using Nighthawk RAX43 router and EAX 15 extender. The combined network performs well for days - weeks, but then connections become unstable. Reason is, the main router and the e...
- Mar 16, 2023
Not a whole lot 🙂
Just set the extender and the 2x devices with issues up as reserved through the primary router.
One other thing to do. If you have mac's/iphones on your network disabled private mac/ip address and icloud relay.
They can cause different ip addresses to be assigned. there should be plenty but maybe over a couple days if you have multiples, its causing issues
Mar 16, 2023Guru - Experienced User
I'm not saying set them all with reserved, just the couple with issues
LGH50
Mar 16, 2023Tutor
Would you say the extender(s) should be the first one(s) with fixed address(es), selected near the high end of the range. It may be hard for the main router to know the address register of an extender that has been (temporarily) off line. The main router then re-connects the extender with the IP address it had before, and does not check what the extender has been doing in the meantime.
Does this make sense?
- plemansMar 16, 2023Guru - Experienced User
Not a whole lot 🙂
