Jon_Endre
Dec 28, 2016Aspirant
The router link LED won't turn on at all whether it is blinking, amber or solid green
hello! i guess it should be said that on my product (model) it says AC750 instead of N750 and nothing that says anything about "passthrough". However, on google images i can see that they have same l...
DarrenM
Jan 04, 2017Sr. NETGEAR Moderator
Hello Jon_Endre
Have you tried to factory reset the extender by holding the reset button and then try the setup again on the extender.
DarrenM
- Jon_EndreFeb 05, 2017Aspirant
Thanks for replying DarrenM!
No i still haven't tried that as i thought that must have been my last resort, but now i will try.
Thank you very much for taking your time to listen,
Jon_Endre
