ronhollingswort
Jun 15, 2016Aspirant
to extend my range, how can i wire cat6 my wn3000rp extender to my router
ronhollingswort
I wasn't clear in my first request, let me clarify. My home is large in length, over 90 ft. My router is located at one end and I'm attempting to extend my Wi-Fi connection to the other. Multiple walls and etc degrade my signal, despite my wn3000rp which I've located approximately midway. I have decided to try hard wiring with cat6 ethernet cable and avoid the fluctuations of my wireless attempt. However, i have seen and read that this is not plausible. Does anyone have any suggestions as to how I can simply use my extender in the fashion I'm trying and wire direct from router to my extender.
- DarrenMJun 22, 2016Sr. NETGEAR Moderator
Hello ronhollingswort
Yes you can connect the router to the extender to get better wifi signal you can see this on page 8 of the manual
http://www.downloads.netgear.com/files/GDC/WN3000RP/WN3000RP_UM_1Feb13.pdf
DarrenM
