DeptfordDude
Oct 31, 2016Follower
Trek N300 PR2000 used as extender: online set-up page different from instructions
I have a brand new AC1600 Modem/Router that I've set-up and it's working perfectly. I have been trying to reconfigure/rename my 3-year-old Trek N300 Travel Router/Extender (PR2000 model) and get it t...
DarrenM
Nov 11, 2016Sr. NETGEAR Moderator
Hello DeptfordDude
When connected to the Pr2000 make sure your wifi is not connected to the main routers network after that go to your run bar then type CMD hit enter then type ipconfig hit enter it should tell you the default gateway you will want to take that ip address and plug it into your browser it should pop the login up for the Pr2000.
DarrenM
