David1946
Aug 04, 2016Aspirant
Trek N300 Wireless as WAN screen display
There is no "Extend my current wireless router’s range check box" on the Wireless as WAN screen display, which shows the available WiFi networks.
- Aug 12, 2016
It seems my software was out of date. An update has fixed the problem.
Thanks for your interest.
Regards
David
DarrenM
Aug 09, 2016Sr. NETGEAR Moderator
Hello David1946
Can you give some more detail on the issue you are having?
DarrenM
