UPPat
Aug 26, 2015Aspirant
Trouble with netgear talking to tivo
I'm totally new at this. My son set my system up. It worked fine. He left for home and when I turn on the TV, choose the Home Theater input which is how he set it up and then use the Tivo remote to.a...
- Nov 03, 2015
Thanks for the info, these things can be difficult to diagnose, especially where items from different manufacturers try to ‘talk’ to each other. If you do get to the bottom of the issue then a further update would be much appreciated.
UPPat
Nov 03, 2015Aspirant
Sorry to have bothered you. I found out my problem had nothing to do with Netgear but was in the way my system was set up throught the receiver. I now have the TIVO connected directly to the TV. When my son comes up (300 miles away) I'll have him try to set it up so that it can take advantage of the speaker system. Thanks for all your help.
Babylon5
Nov 03, 2015NETGEAR Employee Retired
