UPPat's avatar
UPPat
Trouble with netgear talking to tivo
I'm totally new at this. My son set my system up. It worked fine. He left for home and when I turn on the TV, choose the Home Theater input which is how he set it up and then use the Tivo remote to.a...
  • Babylon5's avatar
    Babylon5
    Nov 03, 2015
    Thanks for the info, these things can be difficult to diagnose, especially where items from different manufacturers try to ‘talk’ to each other. If you do get to the bottom of the issue then a further update would be much appreciated.
