Phacops's avatar
Phacops
Trying to set up a Netgear Wifi Extender
Trying to connect range extender to a netgear modem router (model D2200D) - wifi extender powers on, searches for the modem router and I push the WPS button on the modem router. WPS LED blinks faster on the wifi extender and then nothing - no connection.
Ideas?
  • Hi Phacops,
    Welcome to the community!
    You can try manually setting up the extender as described on page 8 of the installation guide on this link.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Phacops,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Phacops,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
      • Phacops's avatar
        Phacops
        Hi Dexter,
        I did set it up manually and funny enough when I check my connection on my computer it does say that I am gettting signals from the range extender and that is how I am connected to the internet. The weird thing is that the client link LED is still red - the others are green (router link LED, the power LED, and the WPS LED.
        Phacops
