MamaBear2016
Sep 04, 2016Aspirant
Trying to set up WN2500RP with blu-ray, to Home WiFi.
A few years ago, I switched our home wifi from 2.4 GHz over to 5 GHz, as the neighborhood was getting crowded here in the west Denver area, with low band home wifi's. So we had two PC's hooked up...
- Sep 04, 2016
The first thing you need to do is to join the WN2500RP to your existing Wi-Fi network. You can't do that from the Blu-Ray player's setup menus. Either use the WPS method or a laptop/smartphone.
After you have completed the join, connect the Blu-Ray player to one of the WN2500RP's Ethernet ports and set the Blu-Ray player to wired mode.
TheEther
Sep 04, 2016Guru
The closest replacement is probably the WNCE3001. The WN2500RP should, however, still work. You can use the WPS method to join the WN2500RP to your existing Wi-Fi network, as documented on page 11 in the manual. Or you can use a laptop or, possibly, a smartphone to connect to the WN2500RP's Wi-Fi signal, NETGEAR_EXT, and proceed to join it to your existing Wi-Fi network by following the setup prompts.
- MamaBear2016Sep 04, 2016Aspirant
I've been trying all afternoon, to connect via the blu ray's internet setup menus. The blu ray sees the netgear unit, but it gives options of connecting wire or wireless and both have failed. I put in the password etc, using the stupid tedious on screen keyboard, and it fails.
The problem is that if it tries to connect with wireless, it may be using the blu ray radio at 2.4 GHz but that takes a different password AND I have the 2.4 GHz radio turned off. Only the 5 GHz is on.
But I'm trying to use the wireless connection of the netgear, which is plugged into the ethernet port of the blu ray, so it's confusing.
I've been at this all afternoon and am frustrated with it, especially putting the password in over & over and having it fail.
Also something about IPV 6.
I saw something about the netgear Genie for PC and downloaded it on my PC here, and it says everything is fine, but I think it's just looking at the complete picture from my PC, which is connected to the wifi fine. It's the blu ray I'm going crazy with. Genie also sees the Netgear box but I'm not sure if I can configure it and get it working from Genie, here on my PC.
- TheEtherSep 04, 2016Guru
TheEther wrote:The first thing you need to do is to join the WN2500RP to your existing Wi-Fi network. You can't do that from the Blu-Ray player's setup menus. Either use the WPS method or a laptop/smartphone.
I just tried that from my laptop, by plugging the WN2500RP into the ethernet port on my laptop, then configuring the laptop with the password. It's saying that it's connecting but not able to use the internet.
I'm frustrated. Cant seem to get the WN2500RP to work with my home wifi.
I think I just remembered something. Do I need to connect this unit via ethernet, to my PC, THEN put the password into this unit and connect to my home wifi, and only then hook it up to the blu ray player and use it as a wired connection? Will the password then reside in this unit, instead of in the blu ray player? Or does the password stay in my PC anyway and render this useless?
Yes, connecting your PC to the unit via Ethernet, then entering your existing Wi-Fi network's password is one of the two methods I already mentioned. The password stays in the unit.
The other method is to use WPS. This is all described in the manual. I suggest you read it, starting from page 11.
