MamaBear2016
Sep 04, 2016Aspirant
Trying to set up WN2500RP with blu-ray, to Home WiFi.
A few years ago, I switched our home wifi from 2.4 GHz over to 5 GHz, as the neighborhood was getting crowded here in the west Denver area, with low band home wifi's. So we had two PC's hooked up...
- Sep 04, 2016
The first thing you need to do is to join the WN2500RP to your existing Wi-Fi network. You can't do that from the Blu-Ray player's setup menus. Either use the WPS method or a laptop/smartphone.
After you have completed the join, connect the Blu-Ray player to one of the WN2500RP's Ethernet ports and set the Blu-Ray player to wired mode.
MamaBear2016
TheEther wrote:The first thing you need to do is to join the WN2500RP to your existing Wi-Fi network. You can't do that from the Blu-Ray player's setup menus. Either use the WPS method or a laptop/smartphone.
I just tried that from my laptop, by plugging the WN2500RP into the ethernet port on my laptop, then configuring the laptop with the password. It's saying that it's connecting but not able to use the internet.
I'm frustrated. Cant seem to get the WN2500RP to work with my home wifi.
TheEther
Sep 04, 2016Guru
Since you have chosen to use a laptop to set up the WN2500RP, follow the instructions starting on page 13. Here is a direct link.
- MamaBear2016Sep 04, 2016Aspirant
Ok, I went and switched it over to my PC and clicked the link in the manual, THEN I remembered how it had to be set up on the other one. I set it up with password etc though my PC, then it worked perfectly.
I took it back to the blu ray, plugged it in and set it for wired, and it worked! Yay! I configured Netflix, then the whole menu of other services popped up in the screen. Yay!
Thanks guys!
Sorry to bother you, it was just a few years ago when I did this in my room, and I didn't remember.
DO you want to delete the thread here?
