MamaBear2016
Sep 04, 2016Aspirant
Trying to set up WN2500RP with blu-ray, to Home WiFi.
A few years ago, I switched our home wifi from 2.4 GHz over to 5 GHz, as the neighborhood was getting crowded here in the west Denver area, with low band home wifi's. So we had two PC's hooked up...
- Sep 04, 2016
The first thing you need to do is to join the WN2500RP to your existing Wi-Fi network. You can't do that from the Blu-Ray player's setup menus. Either use the WPS method or a laptop/smartphone.
After you have completed the join, connect the Blu-Ray player to one of the WN2500RP's Ethernet ports and set the Blu-Ray player to wired mode.
TheEther
Sep 04, 2016Guru
Since you have chosen to use a laptop to set up the WN2500RP, follow the instructions starting on page 13. Here is a direct link.
MamaBear2016
Ok, I went and switched it over to my PC and clicked the link in the manual, THEN I remembered how it had to be set up on the other one. I set it up with password etc though my PC, then it worked perfectly.
I took it back to the blu ray, plugged it in and set it for wired, and it worked! Yay! I configured Netflix, then the whole menu of other services popped up in the screen. Yay!
Thanks guys!
Sorry to bother you, it was just a few years ago when I did this in my room, and I didn't remember.
DO you want to delete the thread here?
