angelazpalmer
Aug 05, 2017Follower
Trying to setup WN3000RP after factory reset, but wizard isn't working and neither is mywifiext.net
Kept getting connected, but not internet connection alert. So I did a factory reset, but the wizard isn't coming up when I connect to NETGEAR_EXT and the website www.mywifiext.net isn't coming up either. I just want to set it back up!
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Angelazpalmer
You could try the WPS setup or if you are able to find the Ip address of the extender you would want to use that in your web browser to connect to the wizard.
DarrenM
