smodnoc's avatar
smodnoc
Follower
Nov 12, 2018
Two routers on one network netgear setup
I have just installed my R7800 and I wondered if I could use my old D7000 at the same time in slightly different locations in my house. My walls are a metre thick and I have three floors so I need all the help I can get with the routers. Any thoughts regarding a two router configuration would be appreciated
1 Reply
  • StephenB's avatar
    If you can get ethernet to another part of your home, you can use the D7000 as an access point.  Instructions are on page 112 of your user manual here: http://www.downloads.netgear.com/files/GDC/D7000/D7000_UM_EN.pdf
    If ethernet is not available, then you could use powerline networking to extend ethernet - for example the PLP2000 product.  There's also a PLPW1000 which has a WiFi powerline module.  It's not quite as capable as the PLP2000+D7000 would be.  But if you need multiple WiFi access points to cover your home, deploying multiple PLPW1000s might be a good way to do that.  You'd only need one ethernet-only device at the router.  The real-world powerline speed does depend on the house wiring.
    Getting a triband extender like the EX8000 is another option - but if your interior walls are a metre thick, it is probably not the best solution for you.
