evh5150ni
Jul 14, 2022Aspirant
Two WiFi extenders (AC1200) clashing?
Hello - I have recently purchased and installed two Netgear AC1200 WiFi Range Extenders (updated to latest firmware), but am immediately finding that there are incessant network dropouts when connect...
Jul 14, 2022Guru - Experienced User
What actual extender do you have? (ac1200 is a speed, not a model)
Do you have them set with separate ssid's? or the same?
In terms of channels, if they're in extender mode, they have to be on the same channel as the router or they can't communicate with it.
How far apart are they and how far from the router are they?
Are they setup in a daisy chain setup or star configuration?
Daisy: Router------>extender------>extender
Star: extender<------Router------->extender
