evh5150ni
Jul 14, 2022Aspirant
Two WiFi extenders (AC1200) clashing?
Hello - I have recently purchased and installed two Netgear AC1200 WiFi Range Extenders (updated to latest firmware), but am immediately finding that there are incessant network dropouts when connect...
evh5150ni
Both extenders are the EX6120.
They have separate SSIDs that I edited during setup.
They are at opposite ends of my home - probably 10 metres apart in a straight line, but on different levels of the house. Each is about 5 metres away from the router, again in a straight line.
They're in star configuration.
I note that I do not get the dropouts when I disable 5Ghz mode on one of the extenders (thereby using 5Ghz on one and 2.4Ghz on another).
Jul 15, 2022Guru - Experienced User
I usually advise people to avoid running more than 1 extender for the reason of there isn't anything controlling the system and they can create interference with each other. I usually advise them to move to a triband mesh system.
In your case, does it help to change which channels you're broadcasting on?
- evh5150niJul 15, 2022Aspirant
This morning I've tried a three different 5Ghz channels and they all have the same problem, seemingly at random.
