brucecjohnson
Nov 28, 2024Initiate
Uanable to Join network "NETGEAR_EXT" Network - Exrender not found
MAC OS SEQUOIA V15.11 Installed Network hardware - Netgear Orbi RBK852 Tri Mesh Router & Satellite
Nov 29, 2024Guru - Experienced User
Wow, your description left a lot to be desired.
You posted about a _ext network but that you have an RBK852 which isn't an extender.
Maybe a better description of what you have for your setup, what you're trying to do, and where it fails would help us to help you better.
brucecjohnson
Nov 30, 2024Initiate
Problem resolved - re booted Router & Wifi Extender
- plemansDec 02, 2024Guru - Experienced User
might mark it solved then so others aren't still trying to fix it
