rludym
Sep 16, 2022Aspirant
Unable to access ex6150v2
I was trying to update firmware and it locked up and now I cannot gain access to it no matter what I do. mywifiext website doesnt work - wired/wireless doesnt work. Reset it multiple times. Any ide...
Sep 16, 2022Guru - Experienced User
What are the leds on it doing? (all of them, color/blinking/solid/etc)
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
rludym
only the power button is on and green. Thx for info - Im on windows and will give it a shot and let you know.
