rludym
Sep 16, 2022Aspirant
Unable to access ex6150v2
I was trying to update firmware and it locked up and now I cannot gain access to it no matter what I do. mywifiext website doesnt work - wired/wireless doesnt work. Reset it multiple times. Any ide...
rludym
I get the advertising NMRP server and then just disconnects. hard to follow directions on site since most are for routers and not extenders. no longer under warranty
Sep 17, 2022Guru - Experienced User
If you can't get tftp/nmrpflash to work, then your device might be bricked. You can try forcing firmware to it through a serial port but that'd require buying parts to do so and finding a guide. not for the faint of heart
- rludymSep 17, 2022Aspirant
ok, sounds like throw away time. thx for the guidance
