NMITGuy
Oct 23, 2015Aspirant
Unable to Access Web UI for EX6200 After Firmware Upgrade
This morning 10/23/2015, I flashed the 1.0.3.68_1.1.104 firmware update to my EX6200 and now it is complaining that the browser(s) I am using do not have Java or it is disabled. It practically freez...
NMITGuy
Dec 09, 2015Aspirant
Nope. It did let me in briefly (a matter of seconds) one day. As soon as I tried going to a different area within the Web UI, it went right back to timing out. I haven't performed a factory reset, as suggested by Netgear staff. I won't do that until I have a reliable replacement. At the beginning of next year, I'm ordering Ubiquiti access points to replace my current AP's. Once I have those in place, I might play around with this Netgear to see if there is anything that can be done to get it to work. If I can't, I'm taking it to the range and blowing it to pieces!
mikeg-pds
Dec 10, 2015Aspirant
I was able to make mine responsive again after doing a factory reset, plugging an ethernet cable to one of the LAN ports, and using the IP 192.168.1.250. I checked the router speed with the new firware and the speed is down to 20 Mbps from 60 Mbps before the firware update. I put the firmware back to version 1.0.1.60_1.1.98 and my speed came back. Hopefully this helps someone else out.
Enjoy!
- gchansen66Dec 27, 2015Aspirant
Just installed this extender and got it all up and running. Went ahead and ran the firmware updater and guess what?
Can no longer get tot he GUI. Having the same looping javascript error. I am on a Mac and have tried Safari, Firefox and Google. All do the same thing. I submitted a support ticket so we'll see if they respond. I'll try the factory reset if I don't hear anything. But does the factory reset change the firmware back? If not, I'm worried about still not haveing access to the GUI and not being able to do setup.
- DarrenMDec 29, 2015Sr. NETGEAR Moderator
Gchansen66
Have you tried to log into the EX6200 by connecting to it directly with a ethernet cord? also you want to log into your router and look at the attached devices and see if you can find the ip address of the EX6200 it may of changed for some reason if so then try that Ip address in your web browser.
DarrenM
