NMITGuy
Oct 23, 2015Aspirant
Unable to Access Web UI for EX6200 After Firmware Upgrade
This morning 10/23/2015, I flashed the 1.0.3.68_1.1.104 firmware update to my EX6200 and now it is complaining that the browser(s) I am using do not have Java or it is disabled. It practically freez...
NMITGuy
Oct 27, 2015Aspirant
Way to not support your products, Netgear. A reminder of why I stayed away from your products for so long. Your support options are terrible. Apparently, my complementary phone support ended in October and now I have to pay you to call in for your botched firmware update? I can't even send an email or do a live chat, like practically all other sites provide for free? Lame, very lame.
I'm taking this extender into the desert and shooting it to pieces. I'll never buy or recommend a Netgear product ever again.
nhann
Oct 27, 2015NETGEAR Employee Retired
Hi NMITGuy,
Do your browsers have any extensions/addons that block ads? You can try disabling them temporarily to see if they're affecting your login.
Here are the screens that should be available. I've tested the lastest firmware:
If possible, I would recommend resetting the unit back to factory default.
- NMITGuyOct 27, 2015Aspirant
No 3-rd party blocking extentions are installed for IE, Firefox or Chrome. The only plugins that are active are Java-related, Google Docs or Adobe Acrobat. I've also tried opening with the browsers in safe mode and no difference. I'll try factory reset once I have a reliable replacement AP in case this is unrecoverable.
