LDLTH
Sep 20, 2020Aspirant
Unable to Connect a Second Extender
I have been using the AC750/EX3700 WiFi Range Extender without any issues for a year. However, after buying a second one, I can't get it to show up since the WPS is not staying lit. It flashes when i...
- Sep 22, 2020
Thanks for your help and patience. I finally got it to recognize the additional extender. First, I had to unplug the first one. Second, I plugged the new one in and reset it. Finally, I was about to see and connect to the NETGEAR_EXT (SSID) WIFI network. After I did all of those things, then I was able to get to set up the new extender. Of course, make sure you give it a name that's different than the first extender.
If Netgear would only have posted this second piece of support, a lot of the frustration would have been eliminated.
LDLTH
Sep 21, 2020Aspirant
Thanks for responding. Since I have an existing extender, do I have to turn existing one off to get the second one to be recognized? I tried to connect before with the Web Browser Setup but I had problems.
Sep 21, 2020Guru - Experienced User
try shutting off the one that is already setup.
- LDLTHSep 22, 2020Aspirant
