Dotdotdot_'s avatar
Dotdotdot_
Follower
Jun 24, 2022
Unable to connect Netgear EX6120 to Virgin Hub via Ethernet.
Hello, I want to set up my Netgear EX6120 extender. I turned it on and plugged the Ethernet cable into the extender. I then ran the cable to my Virgin Hub 4. But I can't connect it to my router. The "Router" LED on the Netgear stays off.
1 Reply
  • plemans's avatar
    when hardwired in, the EX6120 would need to be setup in access point mode and not extender mode.
    Have you ran setup in access point mode?
