BrentDunn
Jun 06, 2014Follower
Unable to connect to website
I am extremely frustrated. I am unable to log onto www.mywifiext.net. This extender is not working and I cannot find any number or website to connect me to Technical Services. Apparently, the infor...
jmizoguchi
Jun 06, 2014Virtuoso
I cannot find any number or website to connect me to Technical Services. Apparently, the information in your Installation Guide is no longer valid??? Do you no longer manufacture or support this product?
1. forum is not support - use to user only
2. If you need support go here
http://support.netgear.com/for_home/default.aspx
on right there live chat
You will likely need to reset the unit
You can search for your model and download any manual you need. Manual will instructs how to reset .
