copterchris's avatar
copterchris
Unable to connect to WNR3500L admin pages when WN3500RP extender active
Hi,
I recently added a WN3500RP extender to my network which is run by a WNR3500L wireless router, and everything works fine EXCEPT I now get 'Unable to connect' when trying to access my main router admin pages (192.168.1.1 or www.routerlogin.com). If I power down the repeater then I can access it fine.
I've got the Repeater IP statically configured to 192.168.1.250, and set the Gateway address to 192.168.1.1. On the main router I've reserved 192.168.1.2-249 for DHCP so as not to interfere with the static IP. I can access the Repeater admin pages at 192.168.1.250.
Any ideas?
Thanks,
Chris
1 Reply
  • I should have mentioned that after powering down the Repeater, it requires a reboot of the main router before the login/admin pages will be served up again.
