kirstyhalf
Oct 13, 2016Tutor
unable to connect via wifi to AC1200 WiFi Range Extender
I have spent a lot of time researching how best to get a WiFi signal to our newly converted office in a summerhouse in the garden. I am totally unable to connect to the range extender via wifi, i am...
TheEther
Oct 13, 2016Guru
You need to provide more details.
What's the model of your extender?
Did you follow the instructions in the manual to set it up?
Did you successfully connect the extender to the main router's Wi-Fi network?
Does your laptop see the extender's Wi-Fi network?
Are you prompted for the Wi-Fi password when attempting to connect to it?
When you used Ethernet to connect your laptop, what did you connect it to? The extender or the main router?
kirstyhalf
Oct 13, 2016Tutor
Model: EX6200
Yes I followed the instructions (using WPS) and it connected no problem
The laptop and my (android) phone see both 2.4 Ghz and 5 Ghz chanels
I get prompted for the password and when i put it in it won't accept it
When I connected via ethernet I connected to the 5Ghz EXT (extender)
Sorry I dodnt provide all this earlier, i was annoyed with it! It does seem like it just wont accept the password. I am using, as per the instructions, the password for the main router, and yes I am putting it in correctly!
No sure if I should do a reset and start again maybe?:mansad:
- TheEtherOct 13, 2016Guru
Try connecting to the extender via Ethernet and then open a browser to www.mywifiext.net. This should connect you the extender's management page. Log in and check the Wi-Fi settings for the EXT networks. You may want to re-enter the Wi-Fi passwords if they are incorrect. Save any changes. Then try connecting to the EXT networks via Wi-Fi.
- kirstyhalfOct 14, 2016Tutor
Thanks for replying, I cant connect to the internet via the ethernet as it won't accept the passwords so i can only connect to the internet via the wifi directly from my router. Can I get to www.mywifiext.net any other way? UPDATE, im now into my account so so i change the passwords to the same as my router instead of the really long one thats in there now?
