Geo9's avatar
Geo9
Unable to connect WN3000RP to Virgin Media Super Hub wifi
Suddenly today the range extender will not connext to my Virgin Media SuperHub Wifi. The Netgear_ext SSID shows up on my iPad but it will not connect. Only the two centre lights come on. I have tried the WPS connect button, turning everything off and on, factory reset but nothing works. I tried connecting directly with an ethernet cable and still can get no response from the extender. Does this sound like a dead box?
  • Fixed it by changing DHCP to STATIC on iPad Wifi detection of Netgear_ext and managed to connect with it and re-installed the settinmgs.
1 Reply
