Sonic98
Jul 19, 2018Aspirant
Unable to extend xfinitywifi hotspot with EX6200
I can't seem to get my extender to work with xfinity. It works fine with the regular passwor network. Hotspot works when it's not extended. I don't get the xfinity login page on devices. Devices don't...
Sonic98
Jul 20, 2018Aspirant
1. Yes it picks it up just fine. I've only set the regular network up with the WPS button, so I don't know if anything different happens
2. No error it gets all the way to the step where it says ' connect you devices" or something like that.
DexterJB
Jul 22, 2018NETGEAR Moderator
Hi Sonic98,
1. Are you then able to connect your devices to the extended network?
2. Are you saying that the setup completes but your devices are just unable to go online when connected to the extended network?
Dexter
Community Team
- Sonic98Jul 22, 2018Aspirant1. It works fine when password protected network is extended, it works when it's not extended, it works when xfinity is not accepted. I can connect to xfinitywifi_extended. I just can't get online, to the xfinity login, or the extender setup page once I connect to it.
2. The setup does appear to complete - DexterJBJul 22, 2018NETGEAR Moderator
