P515
Oct 29, 2015Aspirant
Unable to log in after updating firmware
Hi everyone, I'm hoping someone here can help me out. I've been using a EX6100 wifi extender since July with no problems what so ever. Until now. On the 24th I noticed a firmware update was a...
- Mar 30, 2016
Must hav forgot to update the post, I managed to fix the issue, the internal wifi card just needed an update.
still having the initial problem of been unable to log in to my wifi extender settting and what not.
willi_w
Nov 09, 2015Aspirant
Hi Netgear-Team,
i have currently the same problem with my EX6100(configurated as an access point) too.
Last weekend i updated my firmware from version 1.0.1.28xxx to 1.0.1.36.
This upgrade procedure has keeped all current setting from ex6100, i'm very happy about that.
As i had tryed to login to my admin page from ex6100 i get showed the same login page with information described already from this thread starter.
I have fear to make a factory reset of my access point and have later on a piece of hardware where i can't login and configure.
How to proceed in this case?
Is there availiable one additional "admin" page which one is accessible via full qualified URL?
I need help form NETGEAR in this case.
Thanks in advance.
nhann
Nov 13, 2015NETGEAR Employee Retired
Hi willi_w,
Thank you for sharing your information. Engineers are looking into this case.
You were able to connect to mywifiext.net when you were on firmware 1.0.1.28xxx , correct?
Were you also able to clear browser history/cache and try another web browser?
Then login to mywifiext.net
- willi_wNov 13, 2015Aspirant
Hi nhann,
answers to your questions.
--> i was able to connect directly to IP-Adress, since i'm using EX6100 as an access point, without any problems
--> i did tryed with 3 different Browsers: Google Crome, Mozilla Firefox 42, and IE11 (and additional Maxthon).
each browser has showed same login page and didn't made forward with login procedure.
Best regards
Willi
- nhannNov 18, 2015NETGEAR Employee Retired
Hi willi_w,
Can you please reset the extender to factory defaults and setup the extender as Extender mode (not AP)
and test if you can visit the mywifiext.net page?
If you can access the page, please downgrade to version 1.0.0.28 : http://downloadcenter.netgear.com/en/product/EX6100#searchResults
