P515
Oct 29, 2015Aspirant
Unable to log in after updating firmware
Hi everyone, I'm hoping someone here can help me out. I've been using a EX6100 wifi extender since July with no problems what so ever. Until now. On the 24th I noticed a firmware update was a...
- Mar 30, 2016
Must hav forgot to update the post, I managed to fix the issue, the internal wifi card just needed an update.
still having the initial problem of been unable to log in to my wifi extender settting and what not.
jr123
Jan 02, 2016Aspirant
Hi Netgear Team,
I just updated the firmware on my EX6100 and I'm having the same issue with passwords.
I do not want to do a factory reset as it I do not want to risk not able to login and config the device again.
Any ways to login other than the URL?
Not sure if this would help, my existing password has a ";" in it.
- DarrenMJan 07, 2016Sr. NETGEAR Moderator
Hello jr123
You can log into the EX6100 if you know the Ip address of the device you would use that. Have you tried login into the EX6100 with a ethernet cord and with it disconnected from the main router?
DarrenM
- jr123Jan 09, 2016Aspirant
DarrenM wrote:Hello jr123
DarrenM
It's still complaining about wrong password. I tried using direct RJ45 network connection.
- DarrenMJan 12, 2016Sr. NETGEAR Moderator
jr123
Yea last thing to do is a factory reset.
DarrenM
