jwhart
Sep 29, 2016Aspirant
Unable to log into AC750 EX 6100 Extender in network as access point with Ethernet over AC
I have the unit powered up and all green connected to internet but can't login using either mywifiext.net or IP address 192.168.1.250 as outlined in http://kb.netgear.com/app/answers/detail/a_id/2974...
jwhart
Oct 07, 2016Aspirant
I'm sorry but I don't understand you're suggestions. The EX 6100 is connected with Cat 6 to a wifi over powerline adapter which is plugged into an adjacent outlet. I cannot launch the Netgear "app" using either the mywifiext.net URL or the recommended IP address. If I connect the EX 6100 directly into the source wifi router rather than in the target location, how can it recommend location, etc.?
DarrenM
Oct 10, 2016Sr. NETGEAR Moderator
Hello jwhart
Is the power line extender using the same Ip as the extender maybe?
DarrenM
- jwhartOct 10, 2016Aspirant
I don't know how to determine that? I'm on a mac, if that matters. Thanks for your response!
- DarrenMOct 10, 2016Sr. NETGEAR Moderator
Hello jwhart
Most routers have a screen where it shows the attached devices and gives the Ip address.
DarrenM
Thanks again! My primary router is an Apple Airport Extreme. I have a 2nd Airport Extreme also attached via ethernet and it is what is connected to the wifi over AC adapter. I can access either using Apple's Airport Utility. Do you recommend that I do that on the main computer or the one connected to the 2nd router?
