bringitonskippy
Feb 29, 2016Aspirant
Unable to reset N300RE range extender
I was pointed in the direction of Netgear by the On Networks support page (http://support.on-networks.com/) so I'm hoping someone can help. I bought an On Networks N300RE Range Extender a couple ...
DarrenM
Mar 01, 2016Sr. NETGEAR Moderator
Hello Bringitonskippy
Have you tried to connect to the device via ethernet to re setup the extender I posted a link to the manual here and you can follow from page 8 how to log in.
http://updates1.on-networks.com/support/N300RE/UM/N300RE_UM_26April13.pdf
DarrenM
- greatgranpatMar 05, 2016Aspirant
Hi, Having the same problem, unable to get rid of the last hookup and factory reset not working. I don't have access directly to the router, in a shared wifi setting in an rv park. Any suggestions?
- DarrenMMar 08, 2016Sr. NETGEAR Moderator
Hello greatgranpat
I am talking about hooking your pc to the extender via ethernet to go threw the setup process.
DarrenM
- bringitonskippyMar 09, 2016Aspirant
Hi... you've saved my life, thanks so much! Never even occurred to me to try hooking it up with an ethernet cable. I've now reset it and connected it to my new network. Many thanks indeed!
Just need to point out to other users that the web address now seems to be www.mywifiext.net ("ext" rather than "extender").
